<title>Nederlands Transistorforum - voor Richard</title>
<title>voor Richard (reply)</title>
<content:encoded><![CDATA[[ Geen tekst ]]]></content:encoded>
<link>https://www.transistorforum.nl/forum/index.php?id=30604</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30604</guid>
<pubDate>Tue, 29 Mar 2016 12:54:56 +0000</pubDate>
<category>Aangeboden</category><dc:creator>Leo Snoeren</dc:creator>
<title>Voor Richard (reply)</title>
<link>https://www.transistorforum.nl/forum/index.php?id=30603</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30603</guid>
<pubDate>Tue, 29 Mar 2016 12:54:27 +0000</pubDate>
<title>Philips besturings/bedienings paneel (reply)</title>
<content:encoded><![CDATA[<p>Hallo Leo,</p>
<p>De Philips MMI 160 neem ik graag van je over.<br />
Verder via persoonlijk email.</p>
<p>Vriendelijke groet, Richard E.V.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30597</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30597</guid>
<pubDate>Tue, 29 Mar 2016 11:15:07 +0000</pubDate>
<category>Aangeboden</category><dc:creator>Richard E.V.</dc:creator>
<title>Netwerk tester (reply)</title>
<p>De netwerktester neem ik graag van je over.<br />
<link>https://www.transistorforum.nl/forum/index.php?id=30596</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30596</guid>
<pubDate>Tue, 29 Mar 2016 11:09:34 +0000</pubDate>
<title>Kenwood TD40000a dualband zend/ontvanger (reply)</title>
<content:encoded><![CDATA[<p>Deze Kenwood Dual bander:</p>
<p><img src="images/uploaded/2016032812254056f906a4dda1b.jpg" alt="[image]" width="980" height="839" /></p>
<p><img src="images/uploaded/2016032812255656f906b49c12d.jpg" alt="[image]" width="980" height="830" /></p>
<p><img src="images/uploaded/2016032812261056f906c20d84b.jpg" alt="[image]" width="601" height="735" /></p>
<p>Werkt op beide banden en is compleet met handleiding en microfoon</p>
<p>100 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30567</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30567</guid>
<pubDate>Mon, 28 Mar 2016 08:26:46 +0000</pubDate>
<content:encoded><![CDATA[<p>Deze tester om computernetwerken te testen:</p>
<p><img src="images/uploaded/2016032812170656f904a2415fa.jpg" alt="[image]" width="621" height="735" /></p>
<p><img src="images/uploaded/2016032812172056f904b0b673a.jpg" alt="[image]" width="647" height="691" /></p>
<p>Werkt goed en is nauwelijks gebruikt. Inclusief handleiding en foedraal.</p>
<p>10 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30566</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30566</guid>
<pubDate>Mon, 28 Mar 2016 08:18:18 +0000</pubDate>
<title>Velleman digital speech printje (reply)</title>
<content:encoded><![CDATA[<p>Dit bouwpakket:</p>
<p><img src="images/uploaded/2016032812154856f904546a34a.jpg" alt="[image]" width="628" height="735" /></p>
<p>Is in elkaar gezet en werkt.</p>
<p>4 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30565</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30565</guid>
<pubDate>Mon, 28 Mar 2016 08:16:10 +0000</pubDate>
<title>Bose freespace system controller: (reply)</title>
<content:encoded><![CDATA[<p>Deze besturing voor de hierboven genoemde versterkers:</p>
<p><img src="images/uploaded/2016032812080756f90287d07e4.jpg" alt="[image]" width="980" height="380" /></p>
<p><img src="images/uploaded/2016032812082256f90296dedbc.jpg" alt="[image]" width="980" height="489" /></p>
<p>En hieronder de gegevens van de Bose freespace system controller:</p>
<p>A.1 Electrical specifications and controls<br />
The FreeSpace® system controller (Model 8/32) accepts AC supply voltages from 80 to<br />
265, 50Hz or 60Hz.<br />
A.1.1 Balanced input terminals<br />
Balanced inputs with gain switches, protection diodes, and RFI/EMI noise suppression.<br />
A.1.2 Page input<br />
Gain is switchable for either microphone or line level inputs.<br />
Page trigger sensitivity 275V minimum<br />
Mic input sensitivity 5mV nominal, 250mV maximum<br />
Line input sensitivity 100mV nominal, 1V maximum<br />
Page input impedance 3k (Mic), 200k (Line), balanced<br />
A.1.3 Channel A and Channel B input<br />
Balanced Channel A and Channel B inputs with gain switches.<br />
Line input sensitivity at 300mV 200mV nominal, 300mV maximum<br />
Line input sensitivity at 2V 1V nominal, 2V maximum<br />
Line input impedance 2k (300mV), 7.7k (2V), balanced<br />
A.1.4 Input common mode ripple rejection<br />
40dB or greater<br />
A.1.5 Opti-voice® system circuitry<br />
The system automatically switches from music to page during paging.<br />
A.1.6 Automatic gain control with LED indication<br />
Adjusts paging volume. LED flickers at optimum volume.<br />
A.1.7 Outputs<br />
All balanced outputs with protection diodes, and RFI/EMI noise suppression.<br />
Line output level 6V RMS maximum<br />
Line output frequency response 40Hz 20kHz flat<br />
Line output impedance 600, balanced<br />
Line output paging Channels A and B paging<br />
individually switchable<br />
Model 25, Model 32, or Bose® 102 output level 6V RMS maximum<br />
Model 25, Model 32, or Bose 102 output impedance 600, balanced<br />
Model 25, Model 32, or Bose 102 frequency responseFlat power response with Model<br />
25 or Model 32 loudspeakers<br />
Model 25, Model 32, or Bose 102 paging Channel A On<br />
Channel B Switch selectable<br />
Model 8 output level 6V RMS maximum<br />
Model 8 output impedance 600, balanced<br />
Model 8 frequency response Flat power response with Model<br />
8 loudspeakers<br />
Model 8 paging Channel A On<br />
A.1.8 Power requirements<br />
Determined by power cord supplied 100V, 120V, 220-240V ~ 50/60Hz<br />
A.1.9 Power consumption<br />
7 Watts<br />
A.2 Mechanical specifications<br />
Dimensions: 1 5/8&quot; (H) x 19&quot; (W) x 10&quot; (D)<br />
(4.13 cm (H) x 48.26 cm (W) x 25.4 cm (D))<br />
Weight: 5.5 lb (2.5 kg</p>
<p>25 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30564</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30564</guid>
<pubDate>Mon, 28 Mar 2016 08:08:38 +0000</pubDate>
<title>Zeer zware Inkel versterkers (240 Watt) (reply)</title>
<content:encoded><![CDATA[<p>Deze versterkers:</p>
<p><img src="images/uploaded/2016032812035856f9018e37bde.jpg" alt="[image]" width="980" height="542" /></p>
<p><img src="images/uploaded/2016032812041756f901a1bb996.jpg" alt="[image]" width="980" height="452" /></p>
<p>Met deze eigenschappen:</p>
<p>Features:<br />
- PA-9324: 240W Mono 4 ohm, 70V, 100V<br />
- Balanced XLR Input<br />
- Link Connector On Input for Multiple Amplifier Operation<br />
- Adjustable Input Gain from -12dB to 0dB<br />
- Switchable High-Pass Filter<br />
- Automatic Two-Speed Cooling Fan<br />
- Automatic Thermal Protection<br />
- Output Level Indicator LEDs<br />
- AC Mains or 24VDC Powered<br />
- Rack Mount (3RU)</p>
<p>Technical Info:<br />
- Power Output (RMS) 240W<br />
- Output Impedance or Voltage 4ohm, 70V, 100V (outputs vary depending on country)<br />
- Front Panel LED's -40db, -10dB, Clipping and Protection Circuit Activation<br />
- Frequency Response 70Hz - 18kHz (+1/-3dB)<br />
- THD &lt; 1%<br />
- Signal-to-Noise Ratio &gt; 95dB<br />
- High Pass Filter -3dB@400Hz<br />
- Input Sensitivity and Impedance 1.0V/10kÙ, Balanced XLR<br />
- Input Level Adjustment -12dB - 0dB<br />
- Power Source - AC 100-120VAC or 220-240VAC 50/60Hz<br />
- Power Source - DC 24VDC<br />
- Power Consumption 300W<br />
- Power Switch Push-On/Push-Off with Integral Power LED<br />
- Weight 14kg<br />
- Dimensions (WxHxD) 482mm x 132mm x 280 mm</p>
<p>De versterkers werken, maar of er daadwerkelijk 240 Watt uitkomt kan ik niet testen. Ik heb er drie en vraag 45 euro per stuk, of alle drie samen voor 120 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30563</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30563</guid>
<pubDate>Mon, 28 Mar 2016 08:06:11 +0000</pubDate>
<content:encoded><![CDATA[<p>Dit bedieningspaneel:</p>
<p><img src="images/uploaded/2016032812000256f900a2bac26.jpg" alt="[image]" width="980" height="556" /></p>
<p><img src="images/uploaded/2016032812002056f900b4235e0.jpg" alt="[image]" width="980" height="565" /></p>
<p>Het ding werkt voor zover ik dat kan controleren, ik geef er geen garantie op. Maar bij aansluiten op 24 volt, komt het display op, er klinkt een piepje en bij het indrukken van verschillende knoppen lijkt het ook wat te doen.</p>
<p>25 euro</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30562</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30562</guid>
<pubDate>Mon, 28 Mar 2016 08:02:01 +0000</pubDate>
<title>beursaanbiedingen</title>
<content:encoded><![CDATA[<p>Beste forumlezer,</p>
<p>Nog een week voor de beurs in Driebergen en ik vond nog wat spullen om op te ruimen.</p>
<p>Voor alles geldt:</p>
<p>- Is niet getest, tenzij anders vermeld.<br />
- Kan worden opgestuurd, binnen Nederland voor standaard TNT tarief, tenzij anders vermeld.<br />
- Kan worden opgehaald in Dongen.<br />
- Kan mee naar de beurs in Driebergen 3 april 2016, ophalen voor 12.00 uur.<br />
- Diegene die het eerst via het forum reageert is de nieuwe eigenaar.<br />
- Alle items zijn te koop, geen discussiestuk ervan maken (of een nieuwe draad beginnen).<br />
- Deze aanbiedingen zijn geldig tot 3 april 2016, daarna komen ze te vervallen.</p>
<p>Kijk ook eens op het <a href="http://www.gloeidraad.nl/radioforum/index.php?id=213725">Buizenradio forum</a> voor meer aanbiedingen.</p>
Met vriendelijke groet,</p>
<p>Leo Snoeren</p>
<link>https://www.transistorforum.nl/forum/index.php?id=30561</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=30561</guid>
<pubDate>Mon, 28 Mar 2016 07:56:47 +0000</pubDate>
