<title>Nederlands Transistorforum - Grundig Radiogram Mandello 3WE/FM</title>
<title>Grundig Radiogram Mandello 3WE/FM</title>
<content:encoded><![CDATA[<p>Dear Friends<br />
The radio of the above radio gram has come to me for repair. The radio chasis is CS155 WE/f. In the original version the chasis CS155 it has LW,MW,SW and FM bands but this chasis has MW, 2 SW and FM band. Some body has removed all the components of the power amplifier and I took it up as a challenge to restore the set. The module 7210-309 was also removed and luckily I have been able to get it back. The tracks of this module were damaged and I have repaired the same. Some of the tracks of the main PCB are also damaged and the same is to be repaired. The other components including the power transistors AD161/162 I am arranging locally. Now before I start The actual restoration I need some clarifications which are as follows:</p>
<p>1. On the FM antenna side the PCB 7301-081 is damaged. One small portion is missing. It is a spiral track. How I should I repair this?</p>
<p>2. The coil+ capacitor (C102 and coil 9218-022.01)in series with the gang condenser antenna section and (C103 and same coil in series with the oscillator section of the gang condenser) are missing. What is the solution?</p>
<p>3. I think two thermistors are fitted on the heat sink of AD161/162 - R66 and R67. which are missing.</p>
<p>4. Coils 9218-152.03 connected to the Emitter of the power transistors of both channels are missing?</p>
<p>5 Preset pot R53 is missing which i will be able to arrange.</p>
<p>6. Both the diodes 0310 are missing. What should be the current rating of these diodes?</p>
<p><img src="images/uploaded/2024022907252465e03164a7676.jpg" alt="[image]" width="1017" height="1400" /><img src="images/uploaded/2024022907261465e03196881fa.jpg" alt="[image]" width="1017" height="1400" /><img src="images/uploaded/2024022907265865e031c273647.jpg" alt="[image]" width="1017" height="1400" /></p>
<p>I have marked all the above with red circle on the schematic which I am attaching.</p>
<p>One last help- I have marked at two places with black circle. What are these? are they measuring points? and also what is the use of the coil 9217-019 connected in series with a zenner diode 9731 I presume?</p>
<p>I shall be thankful if experts can guide me on the above points</p>
<p>Regards<br />
P.Rajan</p>
<link>https://www.transistorforum.nl/forum/index.php?id=79255</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=79255</guid>
<pubDate>Thu, 29 Feb 2024 07:27:40 +0000</pubDate>
<category>Algemeen</category><dc:creator>Pandu Rajan</dc:creator>
