<title>Nederlands Transistorforum - Tuner Akai AT-A102</title>
<title>Tuner Akai AT-A102 (reply)</title>
<content:encoded><![CDATA[<p>Nice that it has solved ,Carlos <img src="images/smilies/thumbsup.gif" alt=":)" /></p>
<link>https://www.transistorforum.nl/forum/index.php?id=91687</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=91687</guid>
<pubDate>Tue, 17 Feb 2026 10:25:43 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>Yo Carlos, check your mute circuut, see the output schematic :<br />
(Test by remove the diode)<br />
<img src="images/uploaded/20260216183623699363a71f5f0.jpg" alt="[image]" width="509" height="185" /></p>
</blockquote><p>Hi Cees.</p>
<p>Thanks for the reply, but the problem wasn't in the mute circuit.</p>
<p>Let me explain:</p>
<p>After disconnecting the diode, I tested the tuner on the workbench, and it was working. I reconnected the diode, and it was working fine.<br />
I put the tuner back in the music center, and it started malfunctioning again. (The problem was there.)<br />
I checked everything and discovered that the antenna cable was broken near the connector.<br />
This problem must have happened when I moved the music center during cleaning...</p>
<p>Best regards,<br />
Carlos</p>
<link>https://www.transistorforum.nl/forum/index.php?id=91684</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=91684</guid>
<pubDate>Mon, 16 Feb 2026 22:59:39 +0000</pubDate>
<category>Algemeen</category><dc:creator>edison</dc:creator>
<content:encoded><![CDATA[<p>Yo Carlos, check your mute circuut, see the output schematic :<br />
<link>https://www.transistorforum.nl/forum/index.php?id=91678</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=91678</guid>
<pubDate>Mon, 16 Feb 2026 18:36:30 +0000</pubDate>
<content:encoded><![CDATA[<p>Hello everyone.</p>
<p>I repaired my tuner which had a broken zener diode in the power supply.</p>
<p>It worked very well until now, but another problem has appeared:</p>
<p>The output level is very low, and it's almost inaudible.</p>
<p>I tested the amplifier and it's okay.</p>
<p>I checked the power supply and it's fine.</p>
<p>My suspicion falls on the output integrated circuit, UPC 1235C, but I would like to have some more certainty and for that I would like to know what voltages are present at its terminals.</p>
<p>In the diagram I have, I can't see these voltages clearly.</p>
<p>My question is:<br />
Does anyone have the original schematic, where these values ​​are perfectly visible?</p>
<p>Can you tell me what the voltages are at each pin?</p>
<p>Thank you.<br />
Carlos</p>
<link>https://www.transistorforum.nl/forum/index.php?id=91675</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=91675</guid>
<pubDate>Mon, 16 Feb 2026 16:16:28 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>Yes I have, send me a pm and you get it.<br />
Greetings, Ben</p>
</blockquote><p><br />
Many thanks Ben.</p>
<p>PM sent.</p>
<p>Best regards, <br />
Carlos</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87204</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87204</guid>
<pubDate>Wed, 30 Apr 2025 20:30:19 +0000</pubDate>
<content:encoded><![CDATA[<p>Yes I have, send me a pm and you get it.<br />
Greetings, Ben</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87203</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87203</guid>
<pubDate>Wed, 30 Apr 2025 19:31:58 +0000</pubDate>
<title>Tuner Akai AT-A102</title>
<content:encoded><![CDATA[<p>Hallo.</p>
<p>Does anyone have the service manual for the Akai AT-A102 tuner?</p>
<p>I need it to try to repair my tuner.</p>
<p>Many thanks,</p>
<p>Carlos</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87202</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87202</guid>
<pubDate>Wed, 30 Apr 2025 18:36:13 +0000</pubDate>
