<title>Nederlands Transistorforum - Philips Microfoon N8306 openen?</title>
<title>Philips Microfoon N8306 openen? (reply)</title>
<content:encoded><![CDATA[<p>A more detailed description:<br />
Carefully pry off the Philips badge.It is glued.<br />
Then remove the ring-the ends are very slightly bent in when mounted at the factory.<br />
Now you will see 3 tiny screws.Remove them completely and then it's possible to remove the mic element from the case.<br />
Took some pictures,but sadly the camera stopped working.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=88031</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=88031</guid>
<pubDate>Mon, 16 Jun 2025 17:19:03 +0000</pubDate>
<category>Algemeen</category><dc:creator>Rolf Zetterberg</dc:creator>
<content:encoded><![CDATA[<p>Maybe this helps<br />
<a href="https://audiokarma.org/forums/index.php?threads/philips-microphone-n8306.454822/">https://audiokarma.org/forums/index.php?threads/philips-microphone-n8306.454822/</a></p>
<link>https://www.transistorforum.nl/forum/index.php?id=87899</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87899</guid>
<pubDate>Tue, 10 Jun 2025 21:12:12 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>aangetast door soldeervet? (o.i.d.) (dan schoonmaken en over solderen)</p>
</blockquote><p>Hoe durf je dat te veronderstellen bij een destijd grote electronica fabrikant........<br />
Verder waren er kristalmicrofoons die ook goed konden klinken. Ook bekende merken als SHURE hadden kristal microfoons in het programma,zals deze:<br />
Shure 720a<br />
<img src="images/uploaded/2025061010461968480cfbc31a3.jpg" alt="[image]" width="333" height="500" /><br />
Ergens moet ik hem nog hebben.</p>
<p>Een beschrijving van de 720a<br />
<a href="https://service.shure.com/s/article/shure-tri-polar-microphone-model-720a?language=en_US">https://service.shure.com/s/article/shure-tri-polar-microphone-model-720a?language=en_US</a></p>
<p>Ook de Nederlandse fabrikant Ronette leverde kwalitatef goed kristalmicrofoons.<br />
Nog meer over (kristal-)microfoons.<br />
<a href="https://odemar.home.xs4all.nl/microphones/ronette-mics.htm">https://odemar.home.xs4all.nl/microphones/ronette-mics.htm</a></p>
<link>https://www.transistorforum.nl/forum/index.php?id=87869</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87869</guid>
<pubDate>Tue, 10 Jun 2025 10:31:42 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>Het is een (zeer) eenvoudige Philips microfoon die is ze willen laten lijken op een veel duurdere Philips microfoon, namaak van zichzelf.</p>
</blockquote><p><img src="images/smilies/biggrin.png" alt=":-D" /> <img src="images/smilies/biggrin.png" alt=":-D" /> Dat is wel het toppunt van commercie met als doel om er snel en zoveel mogelijk mee te verdienen.</p>
<p>Groeten, Armand</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87868</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87868</guid>
<pubDate>Tue, 10 Jun 2025 09:55:55 +0000</pubDate>
<category>Algemeen</category><dc:creator>Armand</dc:creator>
<content:encoded><![CDATA[<p>Drie reden, kijken hoe de situatie van binnen is, zijn de soldeerpunten nog netjes schoon of aangetast door soldeervet? (o.i.d.) (dan schoonmaken en over solderen)<br />
Is het dempingsschuimplastic rondje vergaan en aan vervanging toe?<br />
Indien het element defect is, kan ik het dan (makkelijk) vervangen?<br />
(een bijkomende vierde, hoe is het geheel opgebouwd)</p>
<p>Maar, ik blijf er nu maar vanaf.....(mocht hij toch defect zijn, kan ik hem altijd nog &quot;slopen&quot; en de foto's daarvan bewaren.....<img src="images/smilies/wink.png" alt=";-)" /> </p>
<p>rob</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87863</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87863</guid>
<pubDate>Tue, 10 Jun 2025 06:44:52 +0000</pubDate>
<category>Algemeen</category><dc:creator>robbie</dc:creator>
<content:encoded><![CDATA[<p>Volgens mij heb ik zo'n ding ook wel eens geprobeerd te voorzien van nieuw snoer, geen succes inderdaad.<br />
Het is al een hele poosje geleden maar ik meen me te herinneren dat er maar een beetje prullerig kapseltje in zit en dat er zelfs een los stuk gietijzer in de behuizing is geplakt om hem wat &quot;meer gewicht in de schaal te laten leggen&quot; <img src="images/smilies/frown.png" alt=":-(" /> <br />
m.vr.gr.<br />
Anton van den Oever</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87862</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87862</guid>
<pubDate>Mon, 09 Jun 2025 21:28:40 +0000</pubDate>
<category>Algemeen</category><dc:creator>Anton van den Oever</dc:creator>
<content:encoded><![CDATA[<p>Blijjft de vraag:<br />
Waarom wilde je hem demomteren?</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87861</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87861</guid>
<pubDate>Mon, 09 Jun 2025 20:38:37 +0000</pubDate>
<content:encoded><![CDATA[<p>Tja, kan je helemaal gelijk in hebben, maar in de jaren '70 was ik er wat blij mee......hiervoor gebruikte ik &quot;kristalmicrofoons&quot; welke haast overal te koop waren.....<br />
Dan klonk dit echt veel beter!!!!<img src="images/smilies/tongue.png" alt=":-P" /> </p>
<p>rob</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87860</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87860</guid>
<pubDate>Mon, 09 Jun 2025 20:35:44 +0000</pubDate>
<content:encoded><![CDATA[<p>Leo,</p>
<p>Kijk daar heb ik wat aan, iemand die door ondervinding ect......<img src="images/smilies/biggrin.png" alt=":-D" /> <br />
Ik dacht eerst ook zoiets, vandaar mijn vraag......<br />
Dank Leo, ik blijf er met mijn tengeltjes af........en laat de boel gewoon zoals het nu is.....</p>
<p>Gesloten, wat mij betreft.....</p>
<p>Groet en dank voor alle reacties......<img src="images/smilies/smile.png" alt=":-)" /> </p>
Robbbb.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87859</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87859</guid>
<pubDate>Mon, 09 Jun 2025 20:32:18 +0000</pubDate>
<content:encoded><![CDATA[<p>Het is een (zeer) eenvoudige Philips microfoon die is ze willen laten lijken op een veel duurdere Philips microfoon, namaak van zichzelf.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87857</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87857</guid>
<pubDate>Mon, 09 Jun 2025 20:11:03 +0000</pubDate>
<content:encoded><![CDATA[<p>Dag Rob,</p>
<p>Doe geen moeite, het hele ding is dichtgelijmd. Hoe ik dat weet? Ik had dezelfde en daarvan was het snoer afgeknipt. Dus nieuw snoertje plaatsen dacht ik.</p>
<p>Ondanks de beroerde kwaliteit van Philips lijm (denk aan verdwenen merkjes op toestellen en loslatende sierplaatjes op knoppen) zat mijn micofoon behoorlijk goed dicht. Uiteindelijk wel open gekregen, maar het is nooit meer netjes geworden.</p>
<p>Dus als het niet hoeft: zeker niet proberen....</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87854</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87854</guid>
<pubDate>Mon, 09 Jun 2025 13:58:00 +0000</pubDate>
<content:encoded><![CDATA[<p>ehhhhhhhhhhhhhh, ga ik even over nadenken<img src="images/smilies/neutral.png" alt=":-|" /> .......sloop ik zo het merkje niet??<br />
Is er ergens een bouwtekening hiervan??</p>
<p>rob</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87853</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87853</guid>
<pubDate>Mon, 09 Jun 2025 13:11:10 +0000</pubDate>
<content:encoded><![CDATA[<p>Het kan zijn dat er een schroefje onder het Philips logo zit.Je zult hiervoor het logo moeten opwippen met een mesje o.i.d.Succes.<br />
Groeten,<br />
Sietze.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87852</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87852</guid>
<pubDate>Mon, 09 Jun 2025 11:01:26 +0000</pubDate>
<category>Algemeen</category><dc:creator>Sietze Osinga</dc:creator>
<content:encoded><![CDATA[<p>Dank voor je reactie.......<br />
Ik heb hem nog van &quot;vroeger&quot;, jaren 60/70...in origineel (door de tijd aangetast doosje)<br />
Dus geen namaak......<br />
Ik zie van onderen geen schroefjes......<img src="images/smilies/frown.png" alt=":-(" /> </p>
<p>Rob</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87851</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87851</guid>
<pubDate>Mon, 09 Jun 2025 10:23:03 +0000</pubDate>
<content:encoded><![CDATA[<p>Het zou zomaar kunnen dat de onderdelen gelijmd zijn en de micro niet demonteerbaar is, zonder het huis te beschadigen.<br />
<img src="images/uploaded/202506091005346846b1ee2c061.jpg" alt="[image]" width="800" height="473" /><br />
Mogelijk zitten aan de achterzijde, waar het snoer uit komt nog schroefjes, maar die kans is bij dit soort microfoons klein.<br />
Het is een goedkope namaak, die lijkt op een microfoon uit het Phiips professionele ELA programma.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87850</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87850</guid>
<pubDate>Mon, 09 Jun 2025 10:01:46 +0000</pubDate>
<title>Philips Microfoon N8306 openen?</title>
<content:encoded><![CDATA[<p>Dat is mijn vraag, hoe open ik deze zodat ik bij het element kan komen.....?<img src="images/smilies/smile.png" alt=":-)" /> </p>
<p>Rob</p>
<p>(is er ergens een tekening/schema ect.)</p>
<link>https://www.transistorforum.nl/forum/index.php?id=87849</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=87849</guid>
<pubDate>Mon, 09 Jun 2025 07:34:40 +0000</pubDate>
