<title>Nederlands Transistorforum - FP15R12W1T4 IGBT in my DIY inverter</title>
<title>FP15R12W1T4 IGBT in my DIY inverter (reply)</title>
<content:encoded><![CDATA[<p>A capacitive  or inductive load can be a problem for a switcher.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=89967</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=89967</guid>
<pubDate>Tue, 21 Oct 2025 13:40:42 +0000</pubDate>
<title>FP15R12W1T4 IGBT in my DIY inverter</title>
<content:encoded><![CDATA[<p>Hey everyone,</p>
<p>I’m building a small DIY inverter to power my workshop lights, and I chose the <a href="hhttps://www.alldatasheet.com/datasheet-pdf/pdf/1048373/INFINEON/FP15R12W1T4P.html">FP15R12W1T4 IGBT</a>. It looks ideal (1200 V, 15 A), but I’m running into some snags and could use your help.</p>
<p>Here’s what’s happening:</p>
<p>The IGBT switches fine during no-load testing, but once I hook up actual lamps, I start to see weird voltage spikes on the collector and occasional dropouts. I’ve tried snubber RC and stacking MOVs, but spikes still appear when I switch on inductive loads. My gate drive uses 15 V with 10 Ω resistor; layout shows some long traces around the IGBT + diodes.</p>
<p>Does anyone here have experience using FP15R12W1T4 (or similar IGBTs) in inverter builds? Would love to hear how you dealt with:</p>
<p>Gate drive optimization (resistor values, bootstrap / floating gate)</p>
<p>Layout tips for minimizing voltage overshoots / ringing (trace length, ground layout)</p>
<p>Snubber / clamping strategies that reliably stabilize the IGBT under load</p>
<p>Thanks much!</p>
<link>https://www.transistorforum.nl/forum/index.php?id=89957</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=89957</guid>
<pubDate>Mon, 20 Oct 2025 16:37:33 +0000</pubDate>
<category>Algemeen</category><dc:creator>Jordan22xx</dc:creator>
